ThetaGPU has AMD processors on the service nodes (thetagpusn1,2) and AMD processors and NVIDIA A100 GPUs on the compute nodes [see overview page]. The service nodes can be used to create containers and launch jobs, and eventually to use as a cross-compiling environment for compute nodes. Until the cross-compiling environment is set up, the compute nodes will have to be used for compiling. This can be done by using an interactive Cobalt job (via qsub -I), or until we have reserved or added a dedicated build node.
The default programming environment on the ThetaGPU compute nodes is the GNU compiler tools coupled with NVIDIA’s CUDA toolkit.
Note: Symlinks to the project directories are not available on the compute nodes. Use the full path (eg: /lus/theta-fs0/projects/<projectname>) to access the project directory.
For non-GPU codes:
- gcc – for C compiler
- g++ – for C++
- gfortran – for Fortran
For CUDA codes:
- nvcc
For MPI, the latest MPI is in /lus/theta-fs0/software/thetagpu/openmpi-4.0.5.
- mpicc
- mpicxx
- mpif77/mpif90 not configured yet
mpirun is a wrapper in /usr/local/bin that sets the appropriate options and uses the mpirun in the MPI directory above.
On the service nodes, GNU compilers are available.
There are no modules/modulefiles yet set up on ThetaGPU.
