Running TensorFlow with Singularity
Help Desk
Theta GPU Nodes
NVIDIA Container Notes
Getting the container
To get NVidia docker containers which have the latest CUDA and Tensorflow installed, go to NVidia NGC, create an account, search for Tensorflow. Notice there are containers tagged with tf1 and tf2. The page tells you how to select the right one.
You can convert the command at the top, for instance:
docker pull nvcr.io/nvidia/tensorflow:20.08-tf2-py3
to a singularity command by doing this:
singularity build tensorflow-20.08-tf2-py3.simg docker://nvcr.io/nvidia/tensorflow:20.08-tf2-py3
You'll need to run this command on a Theta login node which has network access (thetaloginX). The containers from August, 2020, are also all available converted to singularity here: /lus/theta-fs0/projects/datascience/thetaGPU/containers/
Running on ThetaGPU
After logging into ThetaGPU with ssh thetagpusn1, one can submit job using the container one a single node by doing: qsub -n 1 -t 10 -A <project-name> submit.sh where submit.shcontians the following bash scripting:
#!/bin/bash
CONTAINER=$HOME/tensorflow-20.08-tf2-py3.simg
singularity exec --nv $CONTAINER python /usr/local/lib/python3.6/dist-packages/tensorflow/python/debug/examples/debug_mnist.py
make sure to make the script executable with chmod a+x submit.sh.
The log file <cobalt-jobid>.output should contain some text like this:
Accuracy at step 0: 0.2159
Accuracy at step 1: 0.098
Accuracy at step 2: 0.098
Accuracy at step 3: 0.098
Accuracy at step 4: 0.098
Accuracy at step 5: 0.098
Accuracy at step 6: 0.098
Accuracy at step 7: 0.098
Accuracy at step 8: 0.098
Accuracy at step 9: 0.098
The numbers may be different.
Running Tensorflow-2 with Horovod on ThetaGPU
To run on ThetaGPU with MPI you can do the follow test:
git clone git@github.com:jtchilders/tensorflow_skeleton.git
cd tensorflow_skeleton
qsub -n 2 -t 20 -A <project-name> submit_scripts/thetagpu_mnist.sh
You can inspect the submit script for details on how the job is constructed.
