After you have logged into ThetaGPU, and have a Tensorflow run going, you'll need to know one of your worker nodes so you can SSH to it.
PORT0=9991 PORT1=9992 PORT3=9993 # Select a theta login node N where N=[1-6] ssh -L $PORT0:localhost:$PORT1 $USER@thetaloginN.alcf.anl.gov # after reaching thetaloginN # Replace NN with your thetagpu worker node ssh -L $PORT1:thetagpuNN:$PORT3 $USER@thetagpusn1 # after reaching thetagpusn1 # login to worker node ssh thetagpuNN # now setup your tensorflow environment # for instance run the conda setup.sh script created during the install_tensorflow.sh script # now run tensorboard tensorboard --logdir </path/to/logs> --port $PORT3 --bind_all
